300 amps over 2 cells in parallel is 150 amps, or a discharge rate of 10C for 15 Ah cells, or 15C for 10 Ah cells. I'm no expert on the current capacity of these (or any other) cells, but it sounds aggressive to me.
I assume that this was just an awkward translation, and was intended to be "which cells".
I assume that you intended to say that this high current would only be needed for 8 to 10 seconds (which makes sense), not that the battery would be fully discharged in that time (which would be unreasonable).
Overall, this is a parallel hybrid application, so cells intended for hybrid service (high power density, but not necessarily high energy density) would be suitable. Have you considered part of a production hybrid vehicle battery?
