So do I turn the switch on then once contactor has clicked turn it off againyou need a switch on the either the positive or negative wire to the contactor or else it will be powered on at all times. a key switch or even a toggle switch rated at least 10 amps should work. SPST
Later floyd
My 2 cents. You need to make sure the three throttle wires are correct or nothing will happen or the motor will just run at a fixed speed.
