Hello! I'm doing a "mild" hybrid and I plan to connect an engine of about 30kW through the belt. Tell me which engine is better to use, taking into account the speed of the gas engine 6500, as well as the controller to it?
The second problem with battery assembly. I need only 6 seconds of maximum power to help the gas engine, which is about 300A at 96V. Next will be charging by recuperation
The motor I want to use - MOTENERGY ME1115
Controller - http://kellycontroller.com/kls96601-8080ips24v-96v600asinusoidal-bldc-motor-controller-p-1386.html
I'm very important weight and torque, because. It is not possible to use a gearbox, the electricmotor rpm should maintain the gas engine rpm (6500).
I ask for advice on the engine / controller / high-current battery assembly
