It seems odd that the nameplate does not state the voltage or the frequency. The specifications call for 145 volts, but still no frequency. For a two pole three phase motor, 45 Hz would be 2700 RPM, so 2500 RPM would be about right for 8% slip. But since this is a motor with high power density and designed for higher frequency, it seems more likely to be a four pole motor with 90 Hz base frequency, or six pole for 135 Hz, or eight pole for 180 Hz. The 9000 RPM maximum speed would require 153, 307, 460, and 613 Hz, respectively, assuming a constant 200 RPM slip.
That is 200/3600 or 5.5% slip at 60 Hz and 200/3000 or 6.7% slip at 50 Hz, for a two pole motor. I can't come up with any other way to get the 2500 RPM as rated except with a sync speed of 2700 and 200 RPM slip. The frequency and pole count are unknown factors.
Also, the 87 amps per phase and 145 volts phase to phase works out to about 22 kW. The 15 kW rating would be for 100 volts phase to phase.
