You are still in the low voltage arena and will still consume a significant amount of amperage. More voltage will allow higher rpm and slightly less amperage for a given load. In order to gain more RANGE you need to back off that throttle and be sure you have good LRR tires and that your suspension is set right and that your brakes are not binding.I have a Warp9, a Soliton Controller feeded by 47 CALB 130Ah cells.
First we had 36 cells, than 45, now 47.
But it seems that the more voltage doesn't mean that we consume significant less amperage.
So if I want to increase the range, would "more cells" and higher voltage or bigger cells with more Ah would be the right way?
Mostly just back off the throttle. Coast as much as you can too. Yes, more cells will give you more range.
You went from a 14.9kWh pack to a 19.5kWh pack. Should give a decent range boost as long as you keep your foot off the throttle.
More Power = More Fun = Less Range.
