How are you protecting the Zilla Hairball?
3286 3
I've got a Zilla to install in my truck. The power module Will need a
little splash guarding in the location available under the hood, but the
hairball is posing more of a problem. The form factor of the hairball
isn't a good match for NEMA 4x industrial boxes. Boxes that are long
enough are also very wide, wasting precious under hood space. I suppose
I could put something else inside the box, but all that is hanging out
is high voltage stuff, like contactors and fuses. I'm thinking it's
probably not a good idea to mix 350vdc in the same box as the hairball.
The only other thing I can think of is to build a simple enclosure out
of acrylic plastic to splash proof the hairball.
Does anyone have pictures of what they have done to keep the worst of
the under hood environment away from the hairball?
Paul Wallace
'91 S10 going through a major transformation
1 - 4 of 4 Posts
Discussion Starter · #2 ·
Hey Paul,
I will receive my hairball on Monday and am planning on making a watertight
ABS box (plastic welding) to house it with a clear acrylic cover so it
doesn't lose the cool factor=).
You can get plastic welders reasonably priced from Urethane Supply Company.
If you or anyone else is interested in the outcome, send me an email offline
and I'll send links to where I post the pics once its complete. It will
probably be a few weeks until I get to it.
Regards, Mike
Mike Harvey
Harvey Coachworks and EV
(877) 841-9730
[email protected]
----- Original Message -----
Sent: Friday, July 27, 2007 12:00 PM
Subject: How are you protecting the Zilla Hairball?
> enough are also very wide, wasting precious under hood space. I suppose I
> could put something else inside the box, but all that is hanging out is
> high voltage stuff, like contactors and fuses. I'm thinking it's probably
> The only other thing I can think of is to build a simple enclosure out of
> Does anyone have pictures of what they have done to keep the worst of the
> Paul Wallace
Hello Paul,
I have the motor controller, the hairball about 3/4 above the motor
controller, a large Cableform 600 amp contactor about 2 inches to the right
of the controller and hairball, several plug in glass relays that is mounted
on a terminal board rail and a amp meter shunt which is all mounted on a 1/4
inch aluminum chassis plate with standoffs and the chassis plate is mounted
on a steel plate with bent up sides that is mounted about 8 inches away from
the fire wall using welded on steel extensions to the steel plate.
This assembly is place about 1 inch below the hood, just above the motors.
This unit is than cover with a plastic slip on box with no bottom, more like
a cover, that is fasten to the steel back plate with 3 sheet metal screws
that are on the top.
This allow me to slip off the cover. This type of enclosure allows to work
on the components without any sides that would be a box type of enclosure.
All the power cables, the water cooling tubing, control wires, and a 6 inch
Dayton filter blower fan are all mounted on the steel sides and or with
grommets.
There is air vent on the right side to allow the blower fan to blow the air
through.
You can see this set up at:
http://www.austinev.org/evalbum/470.html
Since I replace the Cableform controller with the Zilla, which fit this
enclosure like a glove, I install a clear panel in the front, so I can see
the hairball status.
The controller mounted up this high is out of any splash of any water. I
also cover the inner fender panels with 1/8 inch thick rubber sheet that is
fasten to the inner fenders with large head plastic pop rivets that I got
from NAPA. This rubber sheet goes all the way down and below the sides of
the motor.
To clean the motor bay, all I have to do is clean the dust with a large car
duster.
Roland
Sent: Friday, July 27, 2007 10:00 AM
> Paul Wallace
I haven't done it yet but was thinking of putting it into a Pelican Case with the appropriate weather tight cable penetrations.
I thought I even saw a Pelican case with a clear top at one trade show. The thumb latch openings would make it easy to get inside and I know those things are waterproof.
Mike
Date: Friday, July 27, 2007 8:23 am
To: Electric Vehicle Discussion List <[email protected]>
> need a
> but the
> hairball
> long
> suppose
> out
> it's
> hairball.
> out
> of
> Paul Wallace
1 - 4 of 4 Posts
