I have a Chins 4x4 UTV that I want to convert to EV. The motor is removed and I have easy access to the Front and Rear Driveshafts. Unfortunately, the transmission is/was part of the engine housing, and all that is gone.
So My option is to find a way to mount one engine to a transaxle that will drive both drive shafts (to allow me access to 4x4 mode), or just remove the front driveshaft and connect to the rear shaft.
Assuming I take the easy route, what is the suggested motor and controller for a 1100lbs unit (dry curb weight), 1400lbs loaded with people. knowing the following:
Max speed we need 15mph
Runtime < 30 minutes
Prefer Lots of Torque over speed
I can make the battery pack (I will use LifePo4 cells) so doesn't matter what motor or control voltage I need.
The splines are as follows:
Front Drive Shaft (see closeup image attached)
The end that slides into the Front Differential has a diameter of 19.5mm (peak of the splines) and it has 19 teeth. The smallest diameter (as measured at the valley of the splines) is 17.5mm (+/- .5mm)
The length of the spline before it hits the snap is 20mm After the snap ring (hidden by the rubber boot) the splines continue another 10mm. The splines themselves appear to be 1mm high
The end of the drive shaft where the drive train will be (i.e. motor or transmission/motor, etc..) the spline portion of the shaft is 25mm long, 19.25mm in diameter, has 19 teeth and the smallest diameter is 17.5mm making the splines themselves 1mm high
Rear Drive Shaft
The end that slides into the Rear Differential has a diameter of 34.5mm (peak of the splines) and it has 26 teeth. The smallest diameter (as measured at the valley of the splines) is 31.5mm (+/- .5mm)
The length of the spline portion of the shaft is 23mm long, The splines themselves appear to be 1.5mm high
The end of the drive shaft where the drive train will be (i.e. motor or transmission/motor, etc..) the length of the spline portion of the shaft is 18mm long, 41.5mm in diameter,has 25 teeth and the smallest diameter of the shaft is 34.5mm making the splines themselves 3.5mm high
Example of the UTV
View of Chassis:
Rear Drive Shaft
Example of the UTV
View of Chassis:
