I am not the best a chemistry,
but I've been read that with copper bus bars for batteries, that you need to prep them to avoided Copper Oxide from forming and increasing ohmic resistance and causing heat to build up leading to cell failure. and also to prevent galvanic corrosion of contacts terminals. ( I am using 82 Ah Nissan leaf batteries)
I've heard of nickle plating the bus bars and a few other ways. but just want a more technical explanation of how to go about connecting up the cells without damaging the batteries or causing any galvanic corrosion
