TEV, thanks for your response. I guess I didn't make it clear that I do have a DC-DC converter. It is only turned on when the ignition is on. Do you mean to keep the DC-DC converter on at all times? Is that what folks typically do? I guess I am worried that if I were to ever leave the lights on when I am at work, it could drain the main pack and affect my range to get back home.Or just install a dc/dc converter like everybody else![]()
Two years is about the average life for a lead acid depending upon the duty cycle and level of maintenance you pull--do you keep the electrolyte topped up, ever over charge or discharge?, etc...Hi all,
I use a 22ah deep cycle auxiliary battery for my electric MR2 and after close to 2 years of driving, it is showing signs of degradation.
How long does your 12V battery last? you mean calendar life? I am using LiFePO4 cells for my 12v battery. I expect them to last as long as everything else. At least 8 years. It is an 8AH battery made up of the 2.3AH A123 cells in a 4S4P arrangement. The DC-DC is 40amp and it takes very little time with the DC-DC on to recharge.I've recently swapped it out with a new one, and took the opportunity to measure the amp draw of my 12V system.
http://blog.mr2ev.com/how-to-size-the-12v-battery-for-an-electric-car/
Please share the following:
How long does your 12V batteries last?
How long can you park your car?
What's your parked amp draw from the 12V system?
Do you use a BMS?
Thanks!
Ken
http://mr2ev.com
kennybobby,Two years is about the average life for a lead acid depending upon the duty cycle and level of maintenance you pull--do you keep the electrolyte topped up, ever over charge or discharge?, etc...
I've parked it 2 weeks without issue.
The car draws about 8ma which is the clock and radio preset maint only. Would be drained too low to turn on the DC-DC converter relay at around 1000 hours of sitting. This is about 42 days. Thinking of getting rid of the car's clock but I think it draws almost nothing.
No BMS is needed with LiFePO4 type cells if you know what you are doing. If you don't know what you are doing a BMS is probably not going to help you. The odd thing is the people who could get the most use from a BMS are those who need them the least.
tomofreno,I am using the same FLA 12V accessory battery that was in the car when I purchased it for conversion. I've had the car almost 4 years, bit over 3 1/2 as an EV. Never had any problem with the 12V battery. It is a Les Schwab 60 month. Unfortunately they didn't mark the date/year of purchase. Earliest year tab on the battery is 2006. It looked fairly new when I purchased the car, so was maybe 1 - 2 years old. The DC/DC is wired to the main pack through an ignition switch controlled relay like yours. Output wired directly to the 12V battery. BMS is the minibms. I have left the car sit for up to 12 days, no problem. Temperatures here typically range from around 100 F in summer to 5 F in winter.
What voltage is it set at, is it adjustable?kennybobby,
I use a deep cycle sealed lead acid 12V battery, so there is really no maintanence. The 12V battery is connected to an AstroDyne SD-350 DC-DC converter to keep it charged when the ignition is turned on. I am not sure how the DC-DC converter controls how to prevent overcharge?
Ken,What voltage is it set at, is it adjustable?
Honn1002, JRP3,Ken,
After looking at the spec sheet of your dc-dc, the output is adjustable. Find out what is the charge voltage of your 12V lead acid battery and adjust the output of the dc-dc to fully charge it every time you key switch to turn on the dc-dc.
Yes. TBS ExpertPro. I think you may be overcharging your sealed battery.tomofreno,
Thanks for the data point, your amp draw sounds like it is much lower than mine even with a BMS. Do you use an SOC gauge like the EV display 2?
Ken
I do have an alarm system and an aftermarket power door lock system. What's been a typical amp draw for your customer? Thanks!Do you have an alarm system on there--last time i saw 'off' currents that high was on a broken alarm system that was draining an ICE customer's battery.
