I've been riding motos since i was 10 and I love to wheelie and was wondering if how much power must a motor produce to wheelie? (relatively low speed start) I'm starting with a supermoto setup that was about 260lbs before removing ice junk, large sticky tires on pavement for good grip. I have gen 2 leaf modules in 10s for 76 volt nominal. people claim all sorts of c ratings for these used modules online but all seem to agree its pleanty, can anyone comment to this?
so far I've been focused on a 5kw bldc motor from golden motors at 72v. I'm afraid it won't be enough power and I'll regret not buying their 10kw bldc.
their controllers for either 5 or 10kw are rated up to 200 amp/ 10kw which as a novice doesn't make sense shouldn't the 10kw controller peak much higher?
I also have found other 5kw controllers rated for 300 amp which were also cheaper. how much can a motor be over amped before problems? I plan on a liquid cooling the motor.
another option I've recently come across are large bldc motors intended for UAV/ "drones" . seems 15-25kw are comparable in price. would these type of motors be suitable for use in a moto? what specs would be important to consider?
