You got it, Francis...
Oh, and thanks for doing a search first then asking if your understanding is correct.
You got it, Francis...I googled and here is what I found.
Ri = ΔU / ΔI
.06/10= 6 milli ohms? Is this right?
I'll second what Tesser says.You got it, Francis...
Just getting my decimal points correct.... The used 160TS cell tested above is at 6mOhms but new cells are about .3mOhms (point 3) or is it 3mOhms?I'll second what Tesser says.
But Fran, 6 mΩ seems too high unless it was a very small cell. What cell did you measure?
However your method looks correct. I use it. Typically I use data points near 1C and 2C. Also, I use V and I values with Fluke grade instruments, maybe more precise than your values.
Regards,
major
Yes they are swollen a "bit", since i have no experience I do not know what amount of swelling is a lot. Here is a photo of the worst swollen one. And I need to make a better connection to the battery....only using small alligator clips.Yeah, 6mΩ is a bit high for a TS 160Ah cell. I have some old style 200Ah cells - moderately abused (okay, seriously abused...) - which measure out at 1.4mΩ with a dI of 100A. Are these cells of yours swollen at all, Francis?
