There's nothing silly about the question.
Automotive lithium-ion batteries can routinely handle about 3 A of discharge for each Ah of capacity, and even more very briefly, so to handle about 300 A of discharge you would need about 100 Ah of capacity. More wouldn't hurt, of course.
100 Ah @ 72 V would be 7.2 kWh. That sounds reasonable for a golf cart, although of course this style of "golf cart" isn't typically used for golf, and capacity depends on how it is used. Again, more capacity is good.
For those who didn't recognize "BBB Recoil", that's the Recoil model of the Bad Boy Buggies line, which is (or was) part of the E-Z-Go division of Textron. Stock, it appears to use nine 8 V golf cart batteries, which are typically rated at 100 Ah to 200 Ah, depending on the rate of discharge; lithium-ion batteries (even LiFePO
4) can handle higher sustained discharge rates and deeper (to a lower state of charge) discharge than lead-acid, so the comparison is reasonable.
