How to install hub motor
10782 Views 6 Replies 4 Participants Last post by  brian_
How would I mount a hub motor like this in a vehicle http://www.qs-motor.com/product/1000w-3000w-electric-car-hub-motor205-model/
1 - 7 of 7 Posts
Okay, now we're in the right section, so I have removed my comment about location in the forum.
These motors include the hub and bearings, and have a non-rotating mounting shaft sticking out the "back" (inboard side). They are primarily intended for motorcycles or conversion of bicycles, which have a suspension arm designed to clamp onto a shaft like this. In a typical four-wheeled vehicle the existing "hub carrier" or "suspension upright" component would need to be replaced by something custom-built with an appropriately sized hole to accept that mounting shaft. The hub carrier must also have a bracket to hold the brake caliper, which must be positioned to fit with the brake disk, which is bolted to the inboard side of the rotating hub/motor case (and is shown in some photos of some models, but not this one).
I don't think any automotive designer would want a hub motor which is mounted this way, and no production car will be designed to accept it directly, but it can be accomodated.
Pretty easy to mount using a beam axle with an appropriate bracket at each end.
Would also be easy to mount on uprights with an appropriate sized hole (looks to be about 28MM) bored in it...….
Would be pretty simple to mount on a Classic Mini rear trailing arm....
I see no problems at all, mounting these to a vehicle, with a little thought and simple engineering...….
They are fairly low powered, and, the vehicle would have to be very light, with very modest top end, probably in the 35 KPH range....
Just by rotating the brackets 90 degrees, you would pick about 3 inches more clearance.....
You could also machine up a bushing to mount the stub axle right in the end of a tube axle...….
Lots of ways to accomplish stuff....
I'm pretty sure no one would even try mounting the double shaft ones on a car, maybe on a three wheeler, but, I'm pretty sure not a 4 wheeler...…..I wouldn't...
Looks like you loose all ground clearance
In a simple beam axle such as shown in the photo linked above, the motor mounting shaft can't reasonably be in line with the beam. The beam can be below the motor shaft (as shown; this is called a drop-beam axle), or above the axle shaft (like a portal axle... not needed or suitable for a road car), or even ahead of or behind the axle shaft (but watch for torque due to the vehicle's weight trying to twist the beam on its spring mounts). The third-generation Honda Civic (for instance) had a rear beam axle with the beam behind and below the hub centres.
I wouldn't want to put all the effort into building a custom suspension and end up with leaf springs and beam axle, but for a very low-performance vehicle it is a cheap and easy way to go.
How do they mount the dual shaft versions?
On a traditional motorcycle front fork or two-sided rear swingarm.
1 - 7 of 7 Posts
