1 - 16 of 16 Posts
Hi All,
I've searched on the forums but not found a thread with a step by step guide to building an RPM sensor to drive a tach and interface with a controller.
I get the basic concept so I'll have a go at making the said thread.
I aim to build my sensor this weekend but I wont be able to test until my Soliton Jr arrives next week some time.
I plan to go down the standard route of using a proximity sensor with a spinning disc with grub screws or bar driven off the back of the motor.
I have purchased a KFPS branded proximity sensor. Specsheet below.
http://ftp01.kfpssensor.com/DC3/TLX18P05E1.pdf
Can someone confirm that this sensor is suitable?
My motor does not have a tailshaft but it does have a threaded hole in the centre of the motor shaft. I plan on putting a larger bolt into this with the disk bolted to it.
I'll then mount the sensor on some aluminium sheet mounted to the 3 smaller tapped holes around the larger one, this will then be angled at 90 degrees to mount the sensor.
Showing the tapped hole and bolt.
showing the back of the motor as is (it has a cover at present)
Sound like a plan?
Cheers,
Mike
Firstly, the datasheet does not indicate if this prox is an inductive type (highly preferred) or a Hall effect type (much less preferred) or even a capacitive type (probably ok, but I've never tried it myself...). If it's an inductive prox then I would use a disc with two notches cut into it for targets.
Secondly, the schematic at the bottom of the datasheet shows an NPN output, but it's labeled as a PNP... So, you might have to try wiring the load resistor both ways. Wire up the sensor to the SJr and try a pullup resistor first - ie, a 1k resistor from TACH to S12V - then pass a piece of ferrous metal in front of the sensor while monitoring the voltage between TACH and SGND. If it does have an NPN output then the voltage will go to ~0V when the sensor sees the ferrous metal. If the voltage doesn't change then try moving the end of the resistor going to S12V over to SGND (ie - a pulldown). NB - to determine if the prox is an inductive or Hall effect type, use a piece of non-ferrous metal as the target after you have confirmed it works with ferrous metal. An inductive prox will sense the non-ferrous metal, a Hall effect prox won't.
Thirdly, note that this sensor has a maximum frequency response of 0.6kHz (600Hz). This shouldn't pose a problem as long as you use 4 targets or less.
Finally, the Soliton controllers need the pulses from the tach sensor to be at least 200us wide (whether starting from ~12V and dropping to 0V when the target approaches or vice versa) or the hardware filter/squaring circuit will ignore them. In other words, the sensor targets need to be a certain minimum width relative to the circumference of the circle they scribe as they rotate. For example, let's say you want to read up to 7200 rpm so you can effectively limit the motor to 6000 rpm (the controller needs to be able to read a higher rpm than the desired limit). If you make a disc out of aluminum and cut two notches in it for an inductive prox to sense, the notches need to be at least 1cm wide if the disc is 12cm in diameter.
The math behind this is straightforward: the linear velocity on the surface of the disc is pi*d then multiply by RPM, divide by 60 to get the surface speed in cm (or inches) per second. Divide the width of the sensing target in cm (or inches) by the surface speed and the distance component cancels out, leaving you with the pulse width in seconds. Multiply that number by 10^3 to convert to milliseconds, or by 10^6 to convert to microseconds. The resulting pulse width must be comfortably larger than 200us at the highest RPM to be read.
WOW!!! that is the best reply I could have hoped for! Thanks Jeffrey:)
I made a start before reading you post. I have used bolts instead of notches but the princple is the same (I think!) I can always change it if needed.
It is an inductive sensor, well thats what I ordered! If its not then it will be going back!
I will also check he math when I'm with the part again, seems well above 200us in my head!
Progress
I was on the lookout for a non ferrous disc, I found an old gas regulator valve for an old welder, pulled it apart and found a perfect brass disc with 6 holes positioned around the outside.
As mentioned earlier my motor doesnt have a tailshaft but does have a threaded hole in the motor shaft.
To mount the disc I simply found a bolt which matched the motor thread, added a washer, inserted it through thhe brass piece, added a brass spacer, added another washer, put on some threadlock on and then a nut.
I then cleaned up the shaft so everything was smooth.
Finally I added two bolts through the existing holes.
EDIT:
and a picture of the pickup on the motor
I'll add pictures and a writup of the mounting for the proximity sensor tomorrow when I make it up in aluminium instead of cardboard!
Cheers,
Mike
Should work fine. A couple thoughts.... If the flange itself it not threaded (through-holes), then you may want to add lock washers to the sense bolts. If threaded, the nut is a secondary lock. . so, no need.
Another thought, if you turned the sense bolts around to they pointed back towards the motor, you could tuck the prox closer to the motor so it doesn't stick out so far.
Right.... update time...
I spent a couple of hours today making up a bracket to hold the sensor.
I originally planned in making it from aluminium but as soon as I bent it, it snapped (twice!). even with heating it. pictures below tell the story!
Plan b was to use some steel strip bent to suit. I used 24x1mm strip.
This simply bolts to the existing holes in the motor.
I had access to a tool for bending strip metal, it has dies for various different angles and different radius curves.
I then measured the that the target sticks out fro the motor, added a bit on for the sensor and bent the strip steel into shape.
I then drilled a hole to cater for the sensor.
Stupidly, I forget to take a picture of it all on the motor!
I diddnt get chance to test what type it is. I'll have a look tomorrow.
Maths time...
Thanks Jeffrey, I'm a bit rusty with my maths so bear with me...
When you say linear velocity do you men the diameter between the targets, multiplying by PI to get the circumference?
It seems as though you are calculating the linear velocity in the first few steps..
Linear velocity being the distance a single point of an object would move at a certain speed (rotations) over a set amount of time (a minute). I Always remeber this as thinking how far a wheel would have rolled if it travelled for 1 minute at a certain RPM...
Anyway...
  • Distance between centre of targets is 58mm
  • Targets themselves are 6mm bolts so 6mm
  • Max speed is 7,200RPM
58mm * PI is 182.212mm
182.212mm * 7,200RPM = 1311926.4mm (~1.3KM travelled by the targets each minute)
1311926.4mm / 60 (seconds) is 21865.44mm (~21M travelled by the targets each second)
21865.44mm / 6mm (width of target) = 3644.24mm
I make that a 364 uS pulse width at 7,200 RPM, way above the 200 :)
Does somebody mind checking the math? (its great fun... I promise!)
piotrsko,
That was the idea of keeping it simple, a bigger nut on the thread makes for a bigger target!
DIYguy,
It's not threaded, I used threadlocker rather than lockwashers, I dont see there being any real load on the bolts so it should be more than adequate.
Unfortunately the sensor is quite long so it wouldnt really help. the space at the end of the motor wont be used for anything anyway as a crossmember sits just in front.
I'll post pictures and results up when I get chance to test everything.
Thanks for all the help.
Cheers,
Mike
Correct, except remember has two m's and traveled has one l... :p
Anyway...
Oops... Nope. Here's the way I do it as it makes more sense to my electrically-oriented worldview:
Find circumference (mm): 58mm * 3.14 = 182mm
Find rotational frequency (Hz): 7200rpm / 60 = 120rps (same as Hz)
Find pulse width (seconds): 6mm / (182mm * 120Hz) = 0.000275s
Finally, I multiply pulse width by 10^6 to get the same result in microseconds: 275us
That's acceptable, though a bit too close to 200us for my preference. However, 7200 rpm also seems a bit high for the limiting RPM. Not sure how big your motor is, but 5500-6000 rpm is usually tops for a 9" diameter motor.
Thanks again,
Your mathematics of looks right to me, mine is wrong!
It makes a lot more sense to me starting in hertz / rotations per second than it does just dividing by 60!
I used 7200rpm from your earlier post as it needs to be able to read over the motor limit. I will set this limit to 4,500RPM for my 9” in the controllers configuration.
Once I receive my controller I'll see how it has worked, I assume logger will show me the rpm?
Cheers,
Mike
P.s. Apologies for the typos, using a tablet and I HATE touch screen keyboards!
And some people wonder how I broke 5 brackets.
yup logger gives you a real time window on your laptop with RPM.
BTW don't forget to disable the controller , AND calibrate the throttle before playing. A first time motor test of only 24 volts wouldn't hurt either.
some thoughts this is going to through the balance of the motor off there will be vibrations from it. Your pulses are going to be short using this type of sensor, a latching hall effect sensor could give better results, the pulse width could be equal time on and off.
Im not exactly sure whats being said here but aluminum is not iron. and hall effect devices are used for most automotive applications.
look here for speed sensors http://gaminde.net
Discussion Starter · #15 ·
Did you get a chance to test it?
Controller arrived yesterday so I've not had chance yet.
I'll post as soon as I've had a chance... Maybe tonight if not then tomorrow.
Cheers,
Mike
Hi all,
It works perfectly!
I've been delayed by some pedal/tach issues but managed to get it all fired up and working today.
Simply wired it into the Soliton with a 1K (pullup) resistor between Signal and Positive. Fired it up and worked first time!
It shows 500 RPM on my 9" motor at full throttle with my test setup (a 12v starter battery!) logger showed 7v or 9v (cant remember) and ~40A. That seems about right to me :)
The picture below shows the simplicity in wiring it up. The other end of this lead plugs directly into the sensor (see earlier pictures).
Nice and simple... thankyou evnetics!
Worth mentioning that the wiring below still needs to be tidied up!
Thanks everyone. If theres any questions or info I've missed then fire it at me!
Cheers
Mike
1 - 16 of 16 Posts
