figure you need 20hp for continuous 50mph (just a swag). the ac50 is much better at continuous power. You get many more continuous hp per/lb with the ac50 vs ac20 (just going by the graphs)
That is my guess, looking at the peak and continuous graphs from hpevs for both motors.So essentially the problem comes down to a AC-20 will not run continuous 20HP but the AC-50 will. Is that correct? Meaning I could not maintain 50mph for a long time with the AC-20!?
Sure there is...Unfortunately there is no Info for the AC-34.
It's pretty clear that they don't think it is adequate for a vehicle as fast and/or heavy as a car. I don't think either the continuous or the peak power are adequate.Here is a list of the typical applications for which this motor can be applied:
• Motorcycle
• Golf Car
• Utility Vehicles
• Hydraulic Pump
• Ground Support Equipment
None of the continuous performance graphs for the AC-2x show anything close to 200 amps being sustained... so no, it can't sustain a 20 horsepower output. The AC-5x is simply larger, which (given the same cooling system) is required to sustain higher power.So to get to the 20hp @ 96 Volts both Motors draw a similar current:
AC-50 ~ 200 A @ 96V
AC-20 ~ 200 A @ 96V
of course the torque and rpm much different.
Hello Frodus,From my using the AC20 on my motorcycle, and my experience selling and supporting these packages through my business (www.emf-power.com), I would not put an AC20 or smaller in a car. It would be suitable for a very small car (smart car, mini cooper, etc), possibly, but I would choose at least an AC3x series or AC5x series motor for a car or truck.
Hello Frodus,
good to hear that you are working with AC-20.
I am planning to develop a small car (comparable to smart) four passengers,
0-60KMH less then 20 Sec.
Fully loaded mass of 1100KG.
Using a direct transmission.
Do you think this motor work?
If you see the cont graph of AC 20 at 36 Volt, the max power is around 6KW. As per one of the Senior member on this post, a car must have around 20 HP (15KW) for driving 50 MPH. So there is a power deficit of 15-6=9KW?
Can you please advice us here. Thanks
I don't.Hello Frodus,
I don't think the torque or HP is high enough to push that car without being severely under-powered. Get at least an AC3x series for a standard size car.I would not put an AC20 or smaller in a car. It would be suitable for a very small car (smart car, mini cooper, etc), possibly, but I would choose at least an AC3x series or AC5x series motor for a car or truck.
