Hi Rishimaze,
Thanks for responding to my moped build post, you've definitely given me a few things to think about!
I do appreciate your advice based on the your experience, but I hope you can see a few positive points in my project too.
I'll take your points in order:-
1. Drop out torque. I had read about this problem. Lots of torque on drop-outs never designed to take it.
I might take your advice and fit a torque arm, but for now I have opened out the drop-out and used a stainless steel plate between the axle flat and the swing arm- just visible in 6th and 7th pics above.
2. Swing arm stiffness, I'll see how it works out, if it's an obvious problem, I'll have to modify it as you suggest.
3. I spoke to an electrician friend and he made the same suggestion, electrics are not my strong point, so I didn't think of the DC-DC converter, obviously a better solution than my rechargeable battery. Thanks.
4. Obviously a disc brake on the front would give me better stopping power. I could build a wheel with a disc brake compatible hub, but I'm not sure how I'd mount the calliper. I want to preserve some of the retro look of the bike, and the forks and front hub are part of that. But if I find the brakes are hopelessly inadequate I'll have to carry out further mods.
5. The battery will be housed in a steel cradle under the frame. I don't plan on riding off road so I hope to keep contact with rocks to a minimum! It will have more ground clearance than it had with its two stroke gas motor. I also want to keep the centre of gravity low for easier handling and manoeuvring.
You're probably right about a mid drive motor, but I'm too far in with this project now to make fundamental changes to the lay out. That will have to wait for the Mark II.
When I bought the motor I told the guy I bought it from what sort of performance I was after (30-35mph) and he suggested this set up. But it does seem I might be looking a fair bit more. I'll take it easy on the first test rides a see how it feels!
I'm hoping the weight won't be a huge amount more than the original bike. The battery should weigh about a kilo more than the original engine. I have removed a lot of original components, it had two chains, a centrifugal clutch, pedals etc. It would also hold maybe 5 litres of petrol (gas) that'll be another 4 kilos. It was also designed to carry a passenger, so even with the average 1960's spouse in mind that's got to be 50kgs of weight I won't be carrying.
Anyway, thanks for your advice. I'll keep you posted on progress.
Steve.
