Turn off your car. Disconnect your battery. Let it sit for an hour to be sure voltages have drained. Re-connect your battery then turn your car back on. Be sure your vehicle is off when you disconnect and reconnect your battery then let us know if that works. It worked on my 2014 Fiat 500E when I had the very same issue.
