Hi All
Ive been doing a bit of searching through the forums to see if there is a list or recommendation of hybrid battery packs for conversions.
Its looking more likely i will use the outlander rear motor and inverter, so will be needing a pack with 300volts.
The outlander battery pack is 13.8KW which could be enough but ideally im after about 20-25Kw pack for my conversion.
Can anyone point me in the right direction for a list / specs of currently used hybrid battery packs?
Cheers
Gaz
Cheers
Gaz
