Forgive me if this thread is in the wrong forum. Just figured I'd follow instructions and start here. I stumbled upon this site like most others (Google) and was convinced that there's a wealth of knowledge to be gained.
To the point. I'm looking for a long-term project. I've always wanted to build a rail/dune buggy, but have never been able to afford to start one. Now that I can afford it I want to take it in a slightly different direction by making hybrid. This different direction is a result of my fascination with my '08 Prius.
I'm assuming most everybody here is dedicated to exclusively electric cars, but I'm hoping that maybe I can get a bit of guidance to at least get me started.
I'm the last person that wants to waste money. I pinch pennies til Lincoln cries so please feel free to criticize or tell me I'm crazy.
My idea for this is:
-Rail frame of tube steel with some aluminum (if it's cheap enough). Design may be mine (and engineering buddies') or some off the shelf idea. I might even buy a used one.
-Will seat at least two maybe four if not too costly.
-Will be used for mild to moderate off-road use and on-road use. I'd like to be able to road register this thing.
-Drive train will consist of the normal hybrid stuff (engine, generator, motor), but will incorporate a differential of some sort. I think an open differential is what I need. The idea is to attach the engine output shaft to the input shaft of the diff. One axle will directly drive a wheel and the other axle would drive a generator which would ultimately charge/power a small battery bank and high torque motor. I may be off in the head, but I'm thinking that at vehicle start, the axle driving the generator would slip and therefore begin delivering power to the elec motor (batteries would assist as well). As the vehicle got up to speed, the axle attached directly to the wheel would start taking power directly from the engine.
-Steering and breaks would be the same stuff used on other buggies.
-Some off the shelf programmable controller to monitor engine, fuel, gen and motor, batteries and other stuff I can't think of now or haven't thought of yet.
That's my idea.
My capabilities:
I'm a network administrator in the real world and a jack of all trades (M.O.N.) everywhere else. I can learn and do just about anything I have interest in and put my mind to.
I have basic tools, socket's, wrenches and others for car work.
My only cutting equipment is an 11A reciprocating saw and 10in miter saw.
I don't have a tube bender but may buy one if it's cheaper than renting.
I have access to MIG welder 220v 180A that should do whatever welding this project will require. If I need something larger, I can call someone from a nearby farm.
I regularly service my own vehicles up to and including larger repairs like transmission clutch replacements. I haven't done a lot of internal engine repair since I've always bartered with a buddy whose an auto mechanic.
Why hybrid?
While I love the idea of not spending money on gas, I like the range I get with my Prius without having to sacrifice power. I regularly get 500-590 miles before I have to fill the tank usually 10-11 gallons. I could probably go a bit further, but how embarassing would it be to have a gallon of gas delivered to America's "fuel sipper". I don't really need the buggy to get that kind of mileage, but I won't turn away from efficiency.
I just want to be able to fill and go.
I don't know much I want to spend or don't want to spend. I don't usually sacrifice quality for price. Although I do walk the middle line a lot.
That's my idea.
My capabilities:
Why hybrid?
