1 - 9 of 9 Posts
Does anyone have solid experience with Hyper 9/ ACX1 controller programming/ fault codes. I’ve been doing test spins and run into a few issues that even with technical support from my supplier I have yet to get a clear answer or solve the problems.
thankfully I have solved most of the issues already. A bad harness from the controller was giving me error codes and interfering with the spin sensors on the motor. This caused me to have wildly varying and incorrect sine/cos values which caused issues with initial set up and spin testing. The only issue I have left right now is a code #5 “inverter 1 over current”. When spin testing the motor this code will pop up after about 50% travel on the DBW accelerator pedal. The motor does a funny little hesitation as you’re pressing the pedal past that 50% point and then the code will pop up. Not sure if it’s a mapping problem or accelerator pedal problem yet.
As far as I can tell this fault code is a result of spinning too fast on the bench with no load on the motor. I will be moving forward with fabrication and most likely will not do another spin test until everything is in the vehicle and ready to go
Bit late to the party. Building an electric snowmobile and trying to do the commission sensor test. Getting fault code 97 "Wrong spin sensor commission request". Any ideas? Additionally a stupid question but how do I hook up my throttle. Manual says to use K1-35 but that is a 5v to the motor
Apologies on the late reply. We discovered that the thumb throttle we were running was wired differently from how we expected. Got it solved and running. Only had a ground and the return wire, wires backwards
1 - 9 of 9 Posts
