Hi
I have been thinking a lot about that last remaining category of ICE which seemingly cannot be beaten by an EV: The Top Fuel dragster.
Here, we're talking 10000Hp+ (estimates, as it's apparently hard to put a 3-second car on a dyno), but just for 3 seconds, and a rebuild is needed at the end of that.
Conversion of energy from electrical to mechanical should be doable in a few hundred kg, since it's such a short time. And it's not like you're gonna be able to fine tune the current any better than just closing and opening a contactor in that timeframe anyway, allthough IGBTs exist which can do it.
But what sort of energy storage, now or within a reasonable time frame, could be able to deliver that amount of current?
About 2kWh is probably enough, but is it possible?
Storing that amount in capacitors isn't technically hard, there's a 600uF 900V cap available which can do 4200A peak. Slap 10 of those in there and you have the energy. But the discharge curve works against you, as the voltage drops quickly, leaving little voltage at the end of the race, when you need it the most to overcome the back EMF. Maybe, since these are light enough, you just overspec enough to coast over the finish line.
Would it be possible? How dumb, on a scale from Tesla to Top Fuel Dragster, would it be?
