1 - 9 of 9 Posts
Discussion Starter #1
I'm buying random parts for the KTM Duke to get a rolling chassis together, then will start looking into the bateries/motors/etc... My aim is to build a fully faired track only bike, so that gets rid of a lot of complications, such as lighting, legality, registration, etc... Target top speed is 100-120mph and range is 30-50miles. Will be for closed circuit use only so the goal is to get maybe 10-15 laps on a charge. Not sure about the weight target, as I've never done this before. So, the main question, How difficult is it and how much would it cost? What parts would I need? Which is the best motor/controller combination for my purpose? If you have a link where I can get the answers It would be great too. Thank you! :D
P.s. I'm simultenously doing more research on the side, but figured I'd post here first, as you guys have actually done this s**t before :D
Most people who do bikes stick with a single gear / belt drive, so it's prudent to get a motor that has some decent RPM capability (>5k). This allows you to select a lower gear for good torque multiplication while still obtaining a good top speed.
Space constraints are the big issue on bikes. LIPO LiCoO2 battery packs tend to have some of the best power to weight but lower cycle life, but if this is an infrequent race bike... it might be an option to consider. They are also volatile and dangerous by comparison to other lithium chemistries, so I would learn before you take the plunge on those.
In terms of cost, 3-phase A/C and brushless DC motors and controllers tend to be more expensive, but they have less issues with maintenance and can usually obtain more power at higher RPM's all things considered equal to brushed motor designs, as they have ways around back EMF limiting the speed. I personally like BLDC motors for good power density and RPM capability, but I settled for a brushed PMDC motor for cost/simplicity.
Parts you want/need:
High voltage cutoff switch capable of your amp draw, contactor rated for your voltage & amp draw, motor controller for your motor type you choose and power output, matching throttle that works with your particular controller, choice of motor, mounts + sprockets/pulleys/belts to get the power to the rear wheel, proper rated fuse, large power wire (usually MINIMUM of 4 awg even on short lengths used on a bike), charger, and choice of instrumentation. I hope i'm not forgetting anything, but there are countless choices and a lot of it is designed to work together... so once you commit to a certain design & voltage, it's prohibitively expensive to change it. Choose right from the start.
Discussion Starter #3 (Edited)
Hi Jay, thanks a lot for your reply. What I'm going to do is start putting together an excel file with the components I need and the ones I decide on, just to keep things organized. Will keep updating this list as and when things get decided. One place I'm taking inspiration from is the GSX-E build. I have also gone trough the Ripperton build, but it's a bit too advanced and high tech for me to dig too deeply into immediately. Mine is going to be a low budget build, so I'll need to keep the pace slow and buy things only when it's time to actually install it. My target is of having an electric bike that can meet or exceed the performance of my RC390 or Ninja 250R.
Something to keep in mind: Some components integrate stuff together. I know some controllers have internal contactors, negating the need for you to buy an external one with a supression diode. Some have precharge resistors integrated as well. Just take that into account since a lower price controller might require a few more components to be purchased on the side.
If you're looking to have 0-60 times in the sub 6 second range, you will need to plan wisely. You need to make some hard decisions about intended range and top speed. It all drastically changes the cost of the build. I suspect you haven't had as many replies because you haven't given us hard constraints.
Discussion Starter #5
Hi, thanks for the heads up! This is honestly just a fun project I'm taking up with my dad and brother, so we don't really have very hard constraints as of now. All I know is we want to keep it around 350-450lbs and keep it competitive with at least a 250-300cc ICE bike. We don't really have very lofty aims of 100miles plus of range, but a high top speed(~100mph) is definitely a priority. For the range, I think at a minimum, it should cover 5-8 laps in a single charge and on a more optimistic level maybe up to 20 laps, or a whole track day. The track length is about 3.3miles.
The reason we're choosing this to be a track only bike is, there is no way we can register it for road use in India and keeping it track only keeps us from having to worry about legalities and the extra complication of wiring lights, horn, indicators, etc...
Discussion Starter #6
Discussion Starter #7 (Edited)
I've been doing a lot of research on motors and the EMRAX 207/8 seems pretty promising, but I'm really worried about the price impact of it. Another motor I really fancied was the 602 dual hub motor by EnerTrac. Again, price is the biggest issue, though the 602 might be considerably cheaper than the 208.
Any advice on controllers if I want to use 48v initially and step up to 96v when funds allow? Also, what kind of AmpHrs would I need if I want a range of 30 miles at the track? Top Speed of 100mph and curb weight of 150kgs(targeted)
emrax motor is definitely the best, but including a controller you would be looking at atleast 5000+ dollars. that is without adapting it to drive a chain.
Discussion Starter #9
Yeah, doesn't make sense for me at all, since mine is basically a hobby build, with no institutional backing. Anyone know if the dual hub motor is worth pursuing? @ripperton, your competition at the TTX GP were using them right?
1 - 9 of 9 Posts
