This was a somewhat common thing in the 90s-2010 or so. At least common enough that people knew about it. I don't know that more than a handful ever got built since most people just owned a second vehicle anyway.
You could make a generator trailer, but that means you need the whole engine on there, plus a generator large enough to power the vehicle at highway speeds (maybe 20hp for your van? 25? That's 15-18kw). Then you charge the batteries (or just drive) from the power cables. Meanwhile, you already have a big electric motor under the hood. Kinda redundant. Maybe you get away with a smaller generator, while the bigger motor under the hood can handle accelerating (dipping into battery use for short term as the smaller genny can't keep up), but still redundant.
So what people do is build a "push trailer". Meaning you drive the trailer wheels with the actual engine. The ghetto way of doing this is to just take the front end of a FWD car, stopping just after after the windshield. A little bit of hotwiring and you're done.
If your motor has regenerative breaking, you can still charge the batteries this way too by applying the brakes while being pushed, though your throttle and brake arrangement gets a bit sketchy that way unless you rig the regen on a second system (brakes should prevent engine from pushing, also brake lights will be on). All possible.
Under the hood the easiest and cheapest thing to use is an old forklift motor, maybe two in your case.
