I assume what you mean by a "pumpkin differential" is a live beam axle, in which the differential is in the axle housing (in a bulge sometimes called a pumpkin). Yes, that's the tendency for 4WD trucks, but not for the "half-ton" size at Ford (the F-150) or any of the pickup trucks at GM... those use an independent front suspension.
Yes, a traditional solid axle with an engine mounted with the crankshaft parallel to the direction of travel, a drive shaft going back and a ring and pinion gear differential, which turns the rotation 90 degrees.
As mentioned in my previous post, my van is rated at more than a ton cargo capacity. I believe it's around 3000 lbs. If you count 15 adults with realistic weights you definitely have more than a ton. I don't know if it's the same running gear under there as a regular 1-ton vehicle or if it's heavier.
My EV dreams were re-ignited when I was changing oil under there. I looked back at the frame and thought about how many batteries you could put in there if you got rid of the drive shaft and engine/transmission, and have absolutely nothing visible from the outside without crawling under the van to look.If you do use a live beam axle in the front (which is a common approach for aftermarket 4WD conversions of full-size vans) then a 4-link would work better than leaf springs, and the motor can sit under the cab area floor (to one side of the original transmission location, because the front differential is offset to one side to clear the engine and match up with the shaft coming from the transfer case).
With a driven independent front suspension (from an Express AWD or 4WD GM pickup), if the original differential is used the motor could be mounted directly to the diff input (if diff's ring and pinion gears give enough reduction for the motor chosen), or back further.
I agree that four motors of the size commonly found in compact EVs would suit the van.
Practical or not, the dream currently is to replace the one-piece axle with 4-wheel independent suspension and a motor on each wheel with a single-speed gearbox. Motors and gearboxes mounted to the frame, with drive shafts with CV joints going out to the wheels. 4wd would be awesome but possibly not practical. The dream (very possibly not practical or within budget) is to have better acceleration than I currently have, especially if the generator trailer comes into play.
If there are commonly available EV-specific motors in the power range that I would need (let's say, 450 hp instead of 350 so 112 hp each wheel) then I would think the whole project could be cheaper that way.
Edit: I'm pretty sure the existing engine, rated at 350 hp, can't pull that power continuously. The electric motors I would use would only need to match the abilities of the existing engine, or preferably surpass those abilities by a noticeable amount.
In contrast, buying new equipment clearly the more motors and controllers you get the more outrageously expensive this whole thing gets.
