Thank you, I believe most or at least some Inverters are also Converters so thinking in terms of EV Conversions and using Damien's or someone elses aftermarket controller one ought to be able to command the Converter to step down the voltage, no?The inverter is a 3-phase inverter (vs either single phase or split phase for chargers). Also, the voltage is different. The leaf inverter is 350v nominal. Chargers only have to be rated for 240v nominal.
Sorry let me clarify I meant an Inverter/Converter combo unit, why can't we use that, so essentially why can't we use a Converter as a Charger?Inverter and charger are two drastically different devices. An inverter doesn't do any voltage conversion, it's just PWM-ing the input voltage. A charger is a full-blown step-up/step-down converter with a dedicated transformer. I can imagine, that an inverter can be used as a charger in some limited cases, but its input/output voltage range is going to be very restricted and efficiency is going to be poor.
Brian provided a more elaborate answer to this, but basically AC or BLDC inverters are typically bi-directional. During regenerative breaking they're effectively acting as rectifiers, converting 3-phase AC input from the motor to DC suitable for charging the battery. While they may not directly control the voltage, they can control the current and thus indirectly control the voltage.Inverter and charger are two drastically different devices. An inverter doesn't do any voltage conversion, it's just PWM-ing the input voltage. A charger is a full-blown step-up/step-down converter with a dedicated transformer. I can imagine, that an inverter can be used as a charger in some limited cases, but its input/output voltage range is going to be very restricted and efficiency is going to be poor.
Disregard his response. His answer applies to controllers intended for brushed motors, but not AC or BLDC controllers.Sorry let me clarify I meant an Inverter/Converter combo unit, why can't we use that, so essentially why can't we use a Converter as a Charger?
I'm sorry I'm confused, disregard who's response?Disregard his response. His answer applies to controllers intended for brushed motors, but not AC or BLDC controllers.
what Frigzy said about "simple PWM" doesn't apply to AC/BLDC controllers(inverters).I'm sorry I'm confused, disregard who's response?
ah, thankswhat Frigzy said about "simple PWM" doesn't apply to AC/BLDC controllers(inverters).
Sorry, but what is the principal difference (electrically-wise) between brushed and brushless inverter except for the 3-rd half bridge?what Frigzy said about "simple PWM" doesn't apply to AC/BLDC controllers(inverters).
I agree with you that stepping up voltage is probably one of the main issues here, when the charging AC input is significantly lower than what the battery pack requires. At the same time, here is what a trivial boost converter looks like :Sorry, but what is the principal difference (electrically-wise) between brushed and brushless inverter except for the 3-rd half bridge?
As it gets to the charging, there are 2 main problems:
1) You get 240V in the outlet (345V DC). How on Earth are you going to step up that voltage to 420V in order to charge a 400V battery pack using, basically, 3 half-bridges? What to do with 120V (level 1) charging?
2) Since you cannot really regulate the voltage, only the duty cycle of the PWM. You have to skip a part of a sine wave in order to bring voltage down, just like a dimmer switch. The power factor of such system is going to be a disaster, no regulation authority ever would approve that for customer use. There is a reason why there is a switching transformer inside your phone charger and not just a PWM-ing transistor bridge.
Thank you for the boost converter animation - that's a good one. The inverter is still missing the main component - an inductor or a transformer. If we somehow add an inductor to the inverter, then yes - maybe it can work as a poor-man charger. Modern chargers are based on resonant topologies. It would take a quite severe modification to the inverter to enable such topology. A proper charger would have a PFC/boost stage. That can be made out of another inverter. I'm not sure if the result can still be called an inverter.I agree with you that stepping up voltage is probably one of the main issues here, when the charging AC input is significantly lower than what the battery pack requires. At the same time, here is what a trivial boost converter looks like :
and the inverter already has the MOSFETs or IGBTs for controlling the phases and current.
My understanding of it is: when the voltage is too high, it's skipping part of the sine wave that's coming from the motor to keep the voltage low. When the voltage is too low, it's boosting the voltage using motor windings as inductors. The efficiency of that process is poor (60-70%) and the power factor is garbage, but no one cares about the power factor within the powertrain. I'm not an expert on Prius though, maybe they put some marvel of electrical engineering in there, who knows.so here is an ignorant question, explain to me how the Prius Inverter/Converter is working then in the video above?
Newb question, in the video below Damien Maguiare demonstrates how you can charge a Prius Gen 2 battery using it's Inverter/Converter single box solution. Since this can be done, why for example does the Nissan Leaf come with a separate battery charger? Why not just rely on the Inverter/Convert in it's pancake stack?
Prius Inverter Battery Charger Part 1
A brushed DC motor controller doesn't have two half-bridges... it has none, right?. It's just a single-channel PWM device, or a very big DC light dimmer.Sorry, but what is the principal difference (electrically-wise) between brushed and brushless inverter except for the 3-rd half bridge?
Very cool simulation!... here is what a trivial boost converter looks like :
