Hello Brilliant People!
I myself am working on a Chevy S-10 conversion. I need a DC controller for a 11" Kostov, or possibly a 9" ADC. Hopefully the Kostov. Essentially though, my battery will be 200v (max) and 144v(min) as it is a 48s Setup of Chevy Volt lithium batteries. Also, this is a utility pickup, and my summers are HOT. The Kostov I believe is rated for 250 amps continuous at 192v. So I need a controller that can sustain this in a hot environment (meaning, 110 - 115 def F - yes it's that crazy around here).... so maybe the controller should be rated for 300 or even 400 amps continuous. That would be good. I'm interested in water cooling.
What I have to offer / trade:
This older IGBT setup which was at one point scrapped for reasons I do not know. I don't even know what it was originally designed to do. And, I don't know if these particular IGBT's are even useful to the geniuses on here. I also have a Curtis 500A 120v controller which is basically acting funny / weak / intermittent and is therefore no use to me. Researching the IGBT's I can see that they are valuable if useful...
But I'm just putting it out there to see if anyone is interested. I can offer a little extra cash with this for the right controller.... I just can't afford a new one like a Soliton Jr. HV which would be ideal.
Attached are pics. This unit basically consists of:
Partial enclosure (mounting of components)
Massive Aluminum Heatsink (original to IGBT's)
Two 24 volt fans (working, tested)
Original Capacitors:
4x Cornell Dubilier 2100 mF 450VDC
IGBT's:
3x PRX PM150DSA120
1x PRX CM100E3U-24H
1x IOR 52MT120KB
IGBT Links (what I could find)
http://www.radwell.com/en-US/Buy/POWEREX/POWEREX/PM150DSA120
http://www.radwell.com/buy/POWEREX/CM100E3U24H
http://www.myfmecorp.com/index.php?ws=showproducts&products_id=397765
I would be happy to test these modules if someone could instruct me how to do so.
I know if you look closely some of the IGBT pins are bent - NOT broken - and I believe they can be straightened but I will leave that to you.
This thing is pretty heavy. I am willing to ship to you as you ship to me.
Anyone with ideas or proposals? PM me or let's chat here.
Cheers!
-Ocean
160.1 KB
103.3 KB
114.6 KB
111 KB
104.4 KB
89.5 KB
137 KB
172.2 KB
