Howdy everyone!
So for starters, I'm about a year or so away from even starting this build. Second, it's going to have a gas generator and is going to be an overland 4x4 with a Land Rover Discovery II as a base. The original plan is to take something like a 2007+ Tahoe 4x4 and drop in the entire drivetrain, put in superduty axles and go up to 35 inch tires; however, I have been playing around with the following idea and I want to know your thoughts.
I have been wanting to use a Volt drivetrain in something, and I think I may have found a way to make this work in the Disco. The original thought was to mount the drive unit longitudinally, keep the transmission, transfer case and axles and weld the diff. I wanted to add a second motor to attach to the front shaft, but tapping into the Volt's charging is iffy at best, and I'm afraid I'd have to give up all of the rear seats in order to fit both the Volt's battery and the batteries required for the second motor to be doing anything. I want to at least have 4 seats.
So, I'm hoping that I can power this thing with just the first gen Volt's drivetrain. It will be a relatively slow vehicle (compared to putting in a 5.3 V8 which has 100 hp more than the original 4.6), but the biggest advantage is going to be the off-road capability which is one of the things I'm most interested in.
So here are the calculations I've done so far and I want to know what you think and if I'm possibly missing anything:
Going backwards with the numbers, the stock tire size of the Volt is 215/55R17. That means it's approximately 26 inches in diameter, which is about 770 revolutions per mile, and that comes out to right around 1300 rpm at the diff when the Volt is traveling at 100 mph (770 * 100 / 60). I'm looking to put 35 inch tires on the Disco. 315/70R17 to be a bit more exact, which is an approximate diameter of around 34.5 inches, and that comes out to around 590 revolutions per mile. Since I'm looking to keep the axles, transfer case and transmission, if the Disco is traveling at 100 mph with those tires, that gives me around 985 rpm axle shaft speed. multiplying the 985 rpm from the shafts through the diff (3.54:1) and then through the transfer case (1.21:1) while driving in 4th gear (0.73:1), the input speed of the transmission is around 3100 rpm.
To account for the discrepancy in RPM, I have contacted the folks at Northwest Fab about my project. They make a crawl box that typically acts as another gear reduction mechanism for 4x4s with a 2.73:1 ratio. I told them I'm looking to install the box backwards to basically create a 0.36:1 overdrive and negate the 2.3:1 diff reduction from the Volt's drivetrain. The maximum rpm output from the Volt would then go from 1300 rpm to around 3500 rpm, giving me the ability to easily drive at highway speeds. Northwest Fab said their units should be able to handle it, but I'll need to add a pump and radiator to cool it.
The coolest part about all of this is that for going off-road, I'm going to end up with 3 reduction gears from the transmission, low range from the transfer case, and another reduction from the backwards mounted crawl box going from "low" to direct drive. First gear in the transmission is 2.48:1, low range on the transfer case is 3.27:1 and the crawl box will be another reduction of 2.72:1 for a total reduction of 22:1 for major torque multiplication and crawl ability.
I know that this will not be an easy project. My main concerns will be getting the speed sensors from the Volt not to freak out and getting the transmission in the Disco to operate right. Now, assuming that can be accomplished (I have some theories on what could be done), is this thing going to be driveable with that little bit of power? Does my math check out?
I also know that between the weight and massive aerodynamic losses, I'm probably only going to get 10-15 miles of electric range vs the standard 30-35. Where I'm really looking to gain something here is in the off-road gears reduction and fuel economy. With the generator running and driving 65 mph, I'm hoping to get 25-30 mpg. If I hit that mileage and am able to keep the original fuel tank (24.5 gallons), that means I'll have more than 600 miles of range. On top of that, I'll be able to install a 2000 watt inverter for camping and have a massive crawl ratio to compensate for the relative lack of power.
So... Thoughts? Let me know if there's something major I'm overlooking.
Thanks!
Thanks!
