Hi Craig
Forget the ultracapacitor - what you need is a new "brain board"
Nissan parts will give 100 hp for 200,000 miles with low warranty failures
If you are willing to drop the reliability then all you need is the brain board to tell the Nissan bits to go for it a bit more
https://pandspowerelectronics.ecwid.com/#!/P&S-Circuit-Boards/c/16287307/offset=0&sort=normal
