I finally got the TS100Ah cells installed and wired this weekend and I am wondering if I should just "go for it" and connect the PFC series charger or use a single-cell charger to bring them all up to 3.7V?
The 38 cells in the string are all at 3.309V (plus or minus 1mV) right now, so I assume they are fairly well balanced and at approximately half capacity (as shipped). Also the total voltage measured is what is expected from the string.
The series charger is setup for a CV of 3.65V per cell so I think the possibility of overcharging is slight but I certainly don't want to find out the hard way that I've overcharged a cell (or two) I have a BMS in development based on cheap celllog8's so I could monitor the voltages during charge and shut off the charger when any cell reaches 3.7V
Charging each cell individually (CC/CV) to 3.7V is possible, but very time-consuming.
What to do?
What to do?
