1 - 20 of 73 Posts
1987 Porsche 924S
I've been lurking on the threads for quite a while but want to introduce our father-son EV conversion project on our 1987 Porsche 924S (which my son has affectionately named "Perl"). We are super excited to make steady progress toward our 80's inspired EV conversion.
Wheel Tire Car Vehicle Automotive tire
I am not a Porsche guy, so I have been surprised by just how much I've enjoyed learning about the Porsche 924 and 944 and their history, not to mention the community around them and just how much people love them, warts and all.
We searched for a car for a while - our criteria being something aerodynamic, light weight, manual transmission, interior and exterior in decent shape but a blown or missing engine. Luckily, we found one in Perl!
What we have done so far - removed the engine, removed the exhaust, cleaned up the engine bay, got all of the lights working and mostly converted to LED, started rebuilding the brakes, and removed the transaxle (so that we can remove the fuel tank). It's been so much fun learning about each piece. We also 3d printed a cover for our torque tube and 3d printed a model of a hyper9 motor to assess how it might fit in the front.
Car Vehicle Hood Motor vehicle Automotive lighting
Where we are and questions we have - so we are about to invest in a motor/inverter and batteries. While I was initially thinking a Hyper9, I've recently become much more interested in the Nissan Leaf motor (I think it will fit better in the engine bay and will be much more affordable). If we do go with the hyper9, i think we would need to shorten the drive shaft to let the motor fit behind the front cross-member of the car, which isn't a huge deal but not super fun either. But in terms of the Nissan Leaf motor, I've been researching and trying to understand options like the openinverter project, and the thunderstruct VCU etc. My issue is every time I search for things on the leaf motor I see tons of threads and videos and I'm not sure what the more recent advice is. I know that so much development has been done in the last few years I guess I'm not sure on what the most current experiences are in dealing with a leaf motor, and what batteries and controllers are being used. Maybe my google-fu is just poor to find the most recent stuff.
Along with trying to find that information (mainly to just give me confidence to go make some purchases), I'm also a little curious about people using batteries with the leaf motor. The specs I'm reading say that motor normally runs with high voltages - something like 350 - 400V from the leaf batteries. How are people generating voltages that high? Are you forced to use the leaf batteries so that the voltage is that high? Or is there some way to use tesla battery modules and not require an insane amount of them in series? I guess I'm just looking for any experiences people know about in terms of what battery packs for an leaf motor EV conversion look like.
Other problems I haven't sorted out in my head yet - how can I at least get enough heater capability such that you can defrost the windshield (which is a safety issue)? Also, if I put a large amount of weight in the rear of the car (more than the weight of a full gas tank), can I just buy stiffer or adjustable shocks?
If anyone has any advice or insight we would love to hear it. We are really looking forward to learning and making memories with this project and hopefully sharing it with everyone else.
  • Our automotive skill level: moderate (I know my way around cars a bit, but haven't ever restored a car from top to bottom)
  • Electricity skills: I have a background in electrical engineering, although I know just enough to be dangerous.
  • Range goal: just something reasonable for driving around Houston. I think if we can get 100 mile range that would be great
  • Performance: nothing insane. Just something fun to drive.
  • Money: whatever it reasonably takes to get something working and make memories with my son.
  • Parts we are considering: Nissan Leaf motor. Not sure on batteries.
First of all, awesome car and awesome project! The 924 with it's rear transaxle configuration is just screaming for a rear-mounted LEAF drivetrain and conversion. Use the 200hp LEAF inverter and really make it scream. Front mounted motor is a waste of space and potential IMO.
Of course you need to visit www.resolve-ev.com and check out the Resolve controller and the creator's own EV 924 if you haven't already seen it.
1987 Porsche 924S
great info. I haven't seen that video yet. I guess i just haven't considered doing it rear mounted but I certainly can. I guess i just need to figure out how one would go about attaching the motor to the rear wheels and where everything would be welded and whatnot. Since it seems so common to just replace the engine with a motor i just figured that was the easiest way to go.
It's certainly more common but I think not as good. If you mount the Leaf drivetrain in the rear where the transaxle lives, then you just need to adapt the CV axles from one transmission to another. That is actually pretty simple in the big scheme of things.
1987 Porsche 924S
maybe i just need to "see" it. I've got two wheels coming out each side of the transaxle... and only one output on the motor... right?
Sort of. The LEAF has a FWD gearbox with a differential and CV axles just like a normal car. The electric motor is bolted to that, the inverter is bolted on top, and then the PDM is bolted on top of that. If you ditch the PDM then it is much shorter. It makes for a very compact drive unit, I'm guessing similar or maybe slightly larger than the Porsche transaxle.
So you replace the transxle with two axles with the LEAF motor+gearbox with two axles.
Check out @windraver's thread for a bunch of photos. He is building a FWD Honda but the same principals apply to using it as a RWD: 1986 CRX EV conversion (Nissan Leaf Donor) - In Progress
This project is very exciting, please keep us updated on it. I would recommend you take videos of your project and post it on YouTube both for memories and for us to enjoy what you are doing. Good Luck!!!
1987 Porsche 924S
Discussion Starter · #9 ·
absolutely... we've been taking some short videos as journals and will be putting them on youtube soon. I'll be sure to post notifications in this thread as well!
watch out for excess battery heat if you go for the 110kw inverter unless you fit the newer and higher amp leaf battery pack in it as well. I just learned that a 110kw inverter and 350v pack takes about 315 peak amps which would melt a 24kwh battery pack (I assume).
1987 Porsche 924S
thanks. I'm not sure I understand everything you are saying. But right now we are planning to use the Nissan inverter that came with the leaf motor.. i believe both were from the same vehicle which i think was a 2015 Nissan Leaf. Is that still a concern?
that would be the 80kw inverter then since they upgraded them to 110kw in 2017 along with a 40kwh pack and 60 optional pack. the 80kw had the 24kwh battery pack so those work together. the 80 seems like a good choice to me though unless you can afford such an expensive 40kwh+ pack to mate with the 110kw inverter.
When you say "I just learned", please cite your source. The context and credibility of such expensive remarks by a third party need to be assessed.
thanks
That's according to the leaf wiki that they upgraded the packs when they upgraded the inverter. I'm not trying to throw out any false info I just thought it was a definite that the high watt inverter would be pulling more current than a used 24kwh pack would be intended for and would lead to hotter temps and even faster degradation.
110 kW divided by 350 V (which is less than half charged for Leaf battery, but that's a realistic scenario) is indeed 110,00/350=314 A. Yes, 350 kW / 24 kWh is 14.6/h, or a discharge rate of almost 15C, which is very high, especially for Leaf components. In stock form, Nissan limits all Leaf batteries to around 3 C:
80 kW / 24 kWh = 3.3 C
80 kW / 32 kWh = 2.5 C
110 kW / 40 kWh = 2.75 C
160 kW / 62 kWh = 2.6 C
1 - 20 of 73 Posts
