1 - 14 of 14 Posts
Hello forums!
My name is Ben, and I am in the early (read: learning!) stages of a project to convert a Volvo 122 Wagon (1966) to electric. I have worked on and brought back from the dead multiple vintage Volvos, so I have experience there, and I have had a few Nissan Leafs as well. Whenever I finish a Volvo project, I quickly sell it and start another, because as much as I love these cars, I just don't enjoy driving them. What I do enjoy driving around town is my Leaf, constrained range and all. I am working on bringing these two things together!
Currently, I have emptied the wagon, and done some rust repair on the battery box area, floor pans, etc. I have rebuilt the rear suspension and front suspension. I had built a b20 with fuel injection (megasquirt) and have an m41 overdrive transmission, but those I will be selling off and I am committed to this direction of the project.
Car Land vehicle Tire Automotive parking light Wheel
I have purchased a crashed but functional 2013 Leaf. From the A-pillar back, the car is immaculate. The car drives and charges. The batteru shows 73% state-of-health on LeafSpy, and that is good enough for my purposes. I have since stripped the front down to access the radiator, which is cracked, and will be addressing that first so that I have a stable test bed I can charge safely while I diagram, label, and learn. Ignore the home improvement stuff encroaching on my garage space :).
Motor vehicle Automotive tire Hood Vehicle Automotive lighting
The plan is still coming together. I'm thinking at this moment of using n m40 4 speed, driveshaft, stock differential, mounting the Leaf stack in the engine bay (EV West adapter plate I have read here exists), and building a battery box above the rear axle for the Leaf batteries. I will either try to find a Resolve-EV controller, or Thunderstruck, or do some significant CAN work to try to re-use as much Leaf as possible.
  • Skills: I am a computer engineer by training, and have good mechanical experience working on vintage cars. I have some experience with electronics (megasquirt conversion, regular 12v car stuff) but no experience with high voltage, yet. Reading and learning.
  • Range: Around-town here in Sacramento, 40-50 miles will do for me. Grocery store, kids school, Volvo meets etc.
  • Timing: I love a project, and this is at least 5 of them at once. I give myself a few years.
  • Investment: I chose two cars I was comfortable with, and cheap compared to Tesla parts. I am into the Volvo for 1k, and into the Leaf for about 3k. I figure another 3-4k for a controller, wiring, gauges, PPE, etc. Reasonable? I will find out.
Appreciate any advice! There are some great threads here on a Volvo 544, and a Volvo wagon, and just so much great details in general. Thank you!
2015 Leaf, 1964 Oliver 1800 Tractor
I look forward to seeing your progress! If you decide to go down the "significant CAN work" road, get in touch - that is where I'm at currently with my leaf/tractor conversion. I have yet to see anyone else go all the way down that road on this forum. I've seen several get things running outside of the car, but then fade away.
the full drive stack canbus has been decoded. running the leaf motor, charger, dcdc, chademo, etc. check out openinverter.org
the zombiverter has a full implantation for running the full leaf stack
the bms is pretty straight forwarded to read messages from.
i have adapter plates and couplers for the leaf motor.
Thank you both for the info! I’ll be in touch about the adapter plates when I get that far. The Volvo M40 and M41 transmissions, while not a plentiful as vw, would be great to have CAD drawings for!
defiantly on the list of belhousing to measure and have a adapter plate for!
Great another Volvo!
I’m supporting a P210 and some 240’s with Leaf motors.
I have a dedicated Leaf to M40 (and M41) and Leaf to M47 (and M45, M46) couplers available.
The one for M40 is rather expensive unfortunately since the Volvo spline tool was very expensive.
I also have adapterplates for Leaf to those gearbox bellhouses.
Engineering Gas Wood Machine Auto part
The Laminated concept
...that's an interesting approach :)
I like it ;)
...& maybe (in some cases) DIY doable for specific (exotic) applications (y)
1 - 14 of 14 Posts
