Introduction - Kona EV Home Battery
1962 Views 8 Replies 7 Participants Last post by  argo.aug
Hello,
Im' Adrian from Poland i will use a Hyunday Kona 64kwh Baterry to make a Homme Energy Bank, need help with the BMS.
1 - 9 of 9 Posts
Welcome Adrian,
Please share your project and details of the BMS. More info is better when requesting help.
Have made the Home Energy Bank from Hyundai Kona battery with help of a friendly commpany in Poland :) they have made for me a BMS communicates it self with internal Battery BMS and controls the Batery Voltages / Temps / Amps and if something goes wrong just shut down the HV Relays - Battery works great with a Sofar HYD 20ktl-3ph
Electrical wiring Electricity Cable Computer hardware Electrical supply
Electrical wiring Electronic engineering Audio equipment Computer hardware Electronic component
Font Screenshot Parallel Rectangle Web page
If sommebody needs a BMS Controller for the Kona / E-niro Baterry please ask :)
That's impressive, thanks for sharing. Good use for a spare bathroom too. :D
A 64k battery for home use? Did you have a 64k battery just "lying around"?
Hi,
First of all: really nice installation.
Do you take the cooling water directly from the tap, or is it recirculating somehow?
I am interested in such a BMS controller. Could you give some more info? Rough price estimate? I might get hold of a Kia 64kWh battery, no other info yet, but it should be very similar to the one you have. Will know more soon. Planning to use it with a Sofar HYD inverter, so very similar to your setup.
Best regards
Can you share the electric diagram of the solution or describe the cutting and connecting wires it refferring to this:
1 - 9 of 9 Posts
