Multiple batteries in series or parallel will deliver the same power.
So to be clear if I arrange the battery bank in parallel (12v) or series (72v) with the appropriate voltage inverter hooked up and have a 10A load hooked up to it I can draw from that series or parallel bank for the same amount of time although one is (12v 750A) and the other (72v 125A) I seemed to be confusing the total amperage with the Ah draw. If I convert to watts it makes more since right..Multiple batteries in series or parallel will deliver the same power.
