I'm very new to all this, but I've been involved with engineering all my life and am now in the motor trade. So... I can do most things, but am not smart enough to do the maths. Kind of a "suck it and see" engineer! LOL
I'm looking into building a small EV and I think back to the early 1970's when my father talked about building an electric Morris Mini Van. His idea was the accelerator pedal (I'm in the UK
) would be nothing more than an on/off switch. The motor would run constantly, reducing the amount of amps it draws on startup. The speed would be controlled by the gear selected and "in between" speeds found by feathering the clutch.
My updated idea is very similar, but with the accelerator pedal having three or four positions. The positions would be as follows starting from the pedal in the "up" position..
1 - OFF (Obviously)
2 - Re-Gen (if possible...)
3 - Idle (limited rpm for gear changes. Maybe by switching to 12v?)
4 - ON (full power)
So basically.... You stick it in gear, press the pedal and go. To change gear... Press the clutch, release the pedal to the next position, change and reverse the process.
I could also just use my fathers off/on idea and add an extra switch for re-gen...
Has anyone ever tried anything like this? Am I missing something that would make this impossible? I know that with a controller, I would have the feel of driving with complete throttle control, but is that really needed?
Also... I am wondering if keeping the flywheel would be a good idea. Instant torque and maybe smoother gear changes being the reason......
1 - OFF (Obviously)
4 - ON (full power)
