Thanks
reiderM,
This example of the F450 seems pretty complicated (at least for my current level of knowledge). But, it is good to know that it can be done with an even bigger truck.
I don't currently have a budget (which might be a blessing or a curse, I haven't decided yet). I certainly don't have unlimited funds, so I guess a budget of 15-20k would seem reasonable to me. But, if there were large gains to be had at a slightly higher budget then I'm open to that too. (and of course, if I can get similar results for cheaper than 20k that would be fantastic).
My range/performance goals in order of priority are as follows:
1. 3-season vehicle. I live in Central NY and the donor vehicle is 2WD so I won't be using it in the winter.
1a. No need for AC or heat in the cabin. If it is hot I'll roll the windows down and if it's cold I'll wear a coat. I presume this will make the build easier and/or give me a longer range/better performance.
2. At a bare minimum I'll need a 40+ mile range. I live in a very hilly area, so I want to be sure that I can go into town (4 miles) and back home with a few stops and possibly even some cargo.
2a. I'd really love a 150+ mile range though. If I could use this as my only vehicle in the Spring-Fall that would be ideal. If the cost isn't too exorbitant, I'd be willing to invest in a more expensive system to get this kind of range over just a minimum around-town truck.
3. I'd like to keep the ability to carry some cargo in the bed. I've been wondering if the bed could be converted into the battery box by using a lot of conventional lead-acid batteries as a solid layer on the 'floor' of the bed, thereby creating a 'new floor that would be about the same height as the wheel wells, and keeping the costs of the conversion a little lower. I don't know if this makes sense or not. Possibly it is better to have fewer, lithium-ion batteries?
4. This model has two gas tanks. I think it would be super cool to have a tesla charger port in one of the gas tank flaps and another, more standard charging port in the other gas tank flap. I'm guessing the ability to have multiple charging ports would add significant cost? This idea is more of a dream because I think it would be pretty rad to park a 1977 Ford next to a Tesla Model 3 at the Super Charger station.
