Hi Everyone,
We're having some sort of a problem with an EV we're working on.
A bit of context :
the frame of the car is of the tubular kind, not unlike this one :
The battery pack is 106S divided in two 56S parts on each side of the frame (each side of the transmission tunnel).
So far we've isolated the whole traction chain from the frame : battery pack / inverter / motor.
The thing is that : when we probe from the battery + to the frame, the multimeter shows around 300V and that decreases to almost 0V with only the voltmeter impedance.
Now when you go around and do the same thing between the battery - and the frame, same thing happens, 300V decreasing to 0 and then you can go to the other side and start again...
Basically when you discharge one side, the other side is "charged" and so on and so on...
We've looked a bit at the literature and the accepted practice would seem to have a several Mohms resistor between the battery + and the frame and the same thing between battery - and frame...
So far, we've tried to isolate everything from the frame so we're a bit reluctant to connect it now... Even though through a Mohm resistor...
Is that an accepted practice?
And in any case, do you have any idea where that "capacitive" behaviour comes from and whether it's something to worry about or not?
Thanks for your feedback!
Marc
A bit of context :
Marc
