Unless you're planning to install ABS, it's going to be absolutely horrible in low traction conditions.
What you'll get is opposite to the Subaru commercial, with your setup: "Transfers power from the wheels that grip to the wheels that slip."
I know Qaife make a limited slip for the Model S LDU, but I haven't followed what's out there for Model 3. You might want to contact them to see if anything is in the works, if it isn't out already.
