What motor controller are you running in this. awesome work, it looks like it'll be a blast to drive around!
Awesome build and trying to do something similar. X2 on the controller question.What motor controller are you running in this. awesome work, it looks like it'll be a blast to drive around!
Thanks! Initial testing was very good! Here’s a separate thread focused on the driveshaft adapter if you’re interested:Looking good! Any driveline vibrations from your early testing? I am doing something similar on my project and trying to figure out if I should just machine the half shaft stub from the motor to accept a spicer flange yoke or might have to do a weld on yoke for fitment but wouldn't be ideal. Also if you want to sell the open dif PM me. Might be interested in trying to weld it for a locked dif. Cant afford the limited slip right now.
Thanks!beautiful!
The front of the Volt battery sits in there. The Volt bulkhead with all the battery coolant connections and HV connections are right inside there. It has a pass through on the bottom for the hv and coolant lines.I may have missed it, but what's the firewall snout for?
