Jet Electrica?
2K views 10 replies 4 participants last post by  M640x
#1 · (Edited)
Hi guys,
I really want to get into EVs and do it pretty cheaply. I was thinking of picking up a Electrica with a GE 9" motor. Basically these are ideas:
SLA batteries are completely shot so I'd figure out someway of converting it to lithium(hopefully cheaply with like a used Leaf pack??)
Also...the batteries are 100% shot, what would be the best way to test the electronics to make sure the controller and motor work?
Comes with a 9" DC series wound...claims 40hp. Would it be possible to get more peak power out of it, nothing crazy but at least a tad zippy? Guy said it has a new controller so maybe that can be a source there?
Not a daily driver...just a project car. I'm both electrically and mechanically inclined so I don't see this as a huge deal.
What do you guys think?
-TP4by3
#2 ·
Re the motor
40 hp continuous is probably OK - but it's the controller that sets the power - I would have no worries at feeding that motor over 100 hp
The basic P & S controller is 500 amps and 150 volts = 75 kW or 100 hp
I'm feeding my Hitachi 11 inch motor about 500 hp
I like Chevy Volt batteries - about $2000 for 16 kWh
#3 ·
Just to be clear, that's a peak power which will only be delivered at one motor speed (what speed depends on the motor characteristics). Below that speed, the controller limits current and the voltage needed to drive that current is roughly proportional to speed, so power drops off in proportion to speed. Above that peak-power speed, more of the voltage is needed to overcome back EMF so the as the speed increases current drops off, and so power drops.
#9 ·
Hi
The volt battery is a number of modules - a 2012 will be seven 2kwh 12S modules and two 1kwh 6S modules
The 12S are 42v - 49v - (Empty to full) - sensible range - you can go a bit higher and lower
The 6S are 21v - 24.5
It's easy to mess with at "module level" - at "cell level" it's very difficult
So mix and match!
Look on the Curtis site for the MAX voltage that they are happy with
You could use two strings of three 12S - which will give you 147v (max) and 12 kWh
Which would leave one 12S and the two 6S modules left over
#10 ·
12kwh would be likely good enough for the meanwhile. Really its probably not going to be much more than a car show project car and maybe take people for some nice electric pedal mashing highway pulls! Maybe later if I need it, I can buy another volt pack and add another 3s2p for 3s4p.
#11 ·
I used to have a Jet electrica. I had the one that was based on the Mercury lynx / Ford escort. Mine had a Curtis 1221 c controller. I had the 96 volt version and while it was slow it actually drove very well. The 120 volt versions have a lot more pep. If you go with lithium batteries you'll lose approximately 800 to 1000 lb. The performance and the range will increase a good bit.
