Hello all, I'm trying to decide between a Kelly KLS6030N and a KLS6018N for my electric ATV (a Venom E-Grizzly, 48V, 1500W stock controller and 3000W BLDC motor according to the vendor). I wish to replace the stock controller as I am not happy with the control of acceleration in the high speed range - it is extremely abrupt off the line even with v low throttle opening, hard to control at low speeds and IMO unsafe especially for younger or inexperienced riders.
The KLS6018N at first glance seems more than adequate for this application as it is rated at 220 A (30 second surge) and 80 A continuous (48V * 80 A = 3,840 W). The KLS6030N is rated at 270 A and 90 A respectively (and $50 more expensive). The reason for my uncertainty is that the Kelly tech support person (Fanny) says the 6018 is too small for my application, quote:
"The current rating is based on the motor phase side. The 48V is on the battery side.
Anyway KLS4812S is mini controller. It can not support 3KW motor. The controller will be overloaded by 3KW motor for running a period."
Can anyone explain this in clearer terms? I don't understand if the stock 1500 W controller gives more than adequate performance, why the smaller Kelly controller won't work as well or better. What I'm thinking is that the controller's output current may be much higher than the input from the battery (at a lower voltage). Could that be the case??
Thanks much for any assistance....
