Kelly Controller ID
1044 Views 7 Replies 3 Participants Last post by  e^2
Can anyone ID this controller? I can't seem to find one like it on their site and the sticker came off long before I got it. It came with a KDHA manual but there are a slew of model numbers on it.
Would be fun to use this on another smaller project of mine if the voltage goes low enough.
Thanks!
1 - 8 of 8 Posts
That does help, thank you! But why would someone put a PMDC controller on my sepex motor? Maybe that is why it wasn't running great. Mine was wired and running at 96V Pb, so mine must be the bigger unit.
http://www.cloudelectric.com/product-p/co-kdz12401.htm
I have a PMDC here, I'll hook it up and see what happens.
ok my one's not what i thought it was .
i got a usb lead and plugged it in and it came up with the model number.
so it kdh12500a 120V 500A happy with that.:)
Sweet! What software did you use? I was worried I had to get the right software before I plugged into it. Should I just download any of their software and plug in? I just got a USB to serial adapter.
Alright, I got to downloading some software and found the right one. I have a KDH09500A.
Are you talking about the 2CM77 aircraft generator you mentioned in another thread? I'll put up my question (post 12 from that thread) RE this motor: With the shunt fields of your motor burned out, maybe the compensating coils are acting as series coils, like in a series motor. They might be too small and out of phase with the brushes for the motor to work as a proper series motor. Could this explain how these aircraft generators seem to work with PWM controllers designed for series or PM motors, but with poor performance?
Since I have the motor out on my garage floor I got to turn it by hand. It takes a lot of force to turn it so I think it burnt out its bearings, causing poor performance. Couple that with the wrong controller and I can see how it wouldn't work quite right.
Since the controller is good enough, I might just run it with my new ADC series motor! Hopefully this weekend I'll get it in and running to see what the real issue was :)
1 - 8 of 8 Posts
