1 - 2 of 2 Posts
So I am currently working on an Ev conversion on my VW Vanagon and I have a question regarding the controller I have. I am using a Kelly Controller, KDH14650B, with a 120V DC motor, ADC FB1-4001, and I want to use a hall effect pedal as a throttle. I am not sure if the Kelly Controller would support that kind of throttle though. Would any of you guys happen to know if that would be supported.
Hall Effect Pedal-
https://www.evwest.com/catalog/product_info.php?cPath=25&products_id=470
Kelly Controller User Manual-http://www.39pw.us/car/doc_ev/mazda/KellyKDHBUserManual.pdf
As long as it's a 5V power hall effect, it should output a linear signal on the throttle signal pin. You'd only use 1 of the 2 hall effect outputs.
Wire Wiper 1, pin 6 to your throttle pin on the kelly. Then throttle 5V on the kelly to the 5V supply pin 3 on the throttle. Then kelly throttle ground to ground pin 5 on the throttle. You'll have to tune it on the kelly, because the span of that throttle is 0.66-3.30VDC. Kelly likely wants 0.5 to 4.5V.
It's confusing with their pinout, where it says WIPER. That would be if it was a potentiometer. With hall effect, it's usually signal 1, signal 2, etc. Wiper means the wiper of a potentiometer.
1 - 2 of 2 Posts
