G
Guest
·Wow, did not expect such fast delivery. In the post on the 11th and here at my door on the 14th. Came from China. Well for Kelly Controllers I am very impressed with the new HP Controllers. Way better than any of the early versions. It is heavy and built quite stout and they finally got some nice beefy terminal posts. No more flimsy connection posts. These look to be built for some heavy duty use. The heat sink that came with the MG is not flat. It has a pretty large bow in the middle of the sink. No way the prior controller was cooling properly. I am quite sure it was going into thermal cutback and to keep trying to drive it that way just caused it to crap out. I am quite sure it was the problem with the original Kelly that came with the kit too. The upgraded one is the one I killed. Kelly was gracious enough to upgrade me to the KDH14800D HP controller for a very nominal fee. I am soooo impressed. Now to get this heat sink to the machine shop to have it milled totally flat. Then I will install the controller. Getting the batteries ready for our first drive.
Photos will be on my site later of the controller. The photos will not do this on justice. It is very stout and a decent weight. I can set voltage cut back and off and throttle adjustments. Pretty simple but has some parameters to adjust.
Pete
Pete
