Hi Everybody I bought a used KDHE 120v 800amp ? as above controller on Ebay, i then bench set it up on 36 volts, and it all worked fine. 2 years later i get to fit on my bike, and using the same wiring, and it does not work? A few pointers, the controller starts up green, but when i open the throttle it goes to red flashing, 2 then 3 = low voltage pack, but after 20 secs goes back to green. Battery is good, at 70v so i tried changing the software voltage min setting down to 24v min, still no change, but it still resets after 20 secs back to green. So it would appear from the fault codes, that the pack is definitely low, BUT IT IS NOT. The only difference i can see from when i originally bench tested the unit, is i had a 36v battery pack and a 36v supply to the main 36v forklift contactor relay. Now i have a 72v pack, but now with a separate 12v auxiliary battery and a 12v Tyco relay with an economizer. If i connect a separate 12v feed to the tyco it pulls in immediately with a loud click, but when in circuit as before, it does not pull in when the ignition is turned on. So from what i can tell, the controller can see 70v on startup, despite the relay not pulling in, as it gets a reading from the pre charge resistor, so when i open the throttle, the voltage drops, and then faults, but after 20 seconds resets green, so the battery is good, and the controller is good. What i want to know is, am i right ?, i am very poor on electronics, and spend ages on a simple schematic, one in ignorance, and two, trying to ensure it doesn't end up in smoke. I am sure i read somewhere in a Curtis manual not to use economizers, is this the problem, and again in ignorance, in an attempt to get it to work, i disconnected the original relay diode (after switching off) in case the tyco already had one, in case it was interfering with the economizer, but on turning on the ignition again, it was still the same, so i reconnected the diode back in circuit before switching off again, just in case. I was tempted to put a jumper across the relay, to see if it worked, and just to see the wheel spin, and confirm my own diagnosis, but held back, just in case i have got it all wrong. Finally if anyone can help put me right, that would be great, but if i am right about the economizer being the culprit, can i just remove the small PCB on the side, and just solder up, or can anybody suggest an alternative, if that's not the case Thanks in advance. yours Dave
