Get oversize and lap it to fit correctly.I have an impulse 9 motor, which has a keyway described on the spec sheet as 0.252/0.250 wide. The to differnt keys available from Grainger are listed as either oversized +0.002 or undersized -0.002.
Does the 0.252 on the spec sheet mean that I should use the oversized key?
They are only $2 each, so maybe I'll just get both to make sure I get a tight fit.
