I'm going to be running a K11-250, series wound. The motor has terminals to allow series or parallel wiring. Below you can see the poles connected for series and are not positioned to easily make buss bars. FYI - those wires were only used for 24V no-load brush run-in and controller testing.
I thought I could just move the terminals and build bus bars shown in red - much easier to do. However, when I disassembled the motor, I found the field windings connected to the terminals with a crimped brass fitting. This does not seem like a connection that will hold up to 1000A bursts and continuous road vibration.
Anyone have thoughts on this? Should I be brazing these connections? The wires are very short so there is not much room to work with the ends. I would hate to break something while trying to fix it when it wasn't originally broken
Thanks for any input/comments!
