Kostov
1321 Views 5 Replies 3 Participants Last post by  piotrsko
G
My Kostov 11" gets its new lightened flywheel and 2100# Empi Pressure plate, clutch disk, throw bearing and gland nut. I need new pressure plate mounting bolts but so far the trial fit is perfect. Nice to see that. We also picked up some parts for the Buggy like a new body to pan gasket and some steering components and new soft brake lines for the rear and new ball joint rubber covers to replace the ones that went bad in the sun. The pan was sitting in the sun for a couple years and they are not designed to live in the sun year in and year out. Things are looking good and moving forward. After the Kaylor test we will be putting in the Kostov for now as the Bus will need more time before it's ready for the electrics.
Pete :)
http://greenev.zapto.org/63ev/63_EV/Kostov.html
http://greenev.zapto.org/63ev/63_EV/Blog/Blog.html
1 - 6 of 6 Posts
I would recommend against using a stock body/pan gasket. It will slowly work the fiberglass between the bolts. The body lip will stay flat where the gasket is compressed at the bolts. Between the bolts the fiberglass will twist up at the edge with the pressure from the rather thick stock rubber seal.
G
You recommend against the body gasket but leave no mention to an alternative choice. Id have to say I would disagree because the body I just pulled from the pan had a pan gasket and it was just old. The inside of the body had a nice aluminum trim around the parameter with mounting holes drilled. This fit on top of the fiberglass edge and allowed a nice smooth pressure around the whole body to hold it in place. The gasket was not warped nor was the fiberglass from the body. I will be reusing the aluminum trim to hold the body in place as it was there originally. It is intact and reusable. If however the gasket does squeeze out I will just dismantle the vehicle and take it out if that time comes.
Unless you have a better idea? I am all ears. This is after my first ever Buggy. Plenty of bugs but never a buggy.
It's lookin better each day. Still need a good steering column and CV axles and a Seat and Rail. Then I can test drive and maybe even take it to DMV once assembled.
When I got my buggy it has been bolted to the pan for likely 20 years with a pan gasket using bolts and fender washers. The body flange to attach to the pan was lifted on the inside between each of the bolts. It actually caused some stress cracking in the fiberglass. I did some grind and replace of fiberglass on the inside to get rid of cracking (while doing extensive fiberglass replacement to the sides where the roll bar whacked the body when the previous owner flipped it.) I have restored the strength but you can still see the ripple in the lip if you look inside my buggy. I just bolted the body directly to the floor pan without any gasket. It has been that way for the last 18 years without any problems. My buggy isn't some nicely sealed sedan anymore.
It sounds like you already have one of the solutions I was thinking about. I had considered using 1/4 inch aluminum strips on top of the body inside the car and then using countersink cap screws in that to bolt the body to the floor. Since my body lip was already all wavy I didn't do it, instead using regular bolts and fender washers again and painting them with the body. If you sink batteries into the floor pans the body will be supporting them (the body supports the floor on the Beetle pan) so your setup would be good. My fiberglass body has had no problem supporting 3 Optima batteries (125 lb.) on each side for the last 10 years with the bolts and fender washers.
I also left out the very front and rear bolt that attaches the body to the floor. It is fairly common to have the floor boards crack inward from each corner because the pan horns don't flex but the sheet metal floor is flexes along with the fiberglass body. That fight gets taken out on the corners. I had to do crack repairs to all 4 corners when I got the buggy but have only had to repair one corner a second time, the right rear where the SLI battery used to sit. That whole area is a collection of rust and crack repairs.
That's a beautiful sight. Did you spin it up to make sure it doesn't vibrate? What about having those starter teeth machined off?
Pete :)
IMHO those teeth are way too handy for assorted nut tightening jobs to remove. Notice the official flywheel tool in top of picture
1 - 6 of 6 Posts
