1 - 14 of 14 Posts
Hi All,
I’m building a Lancia Stratos replica and have all the drawings and 3D models of the chassis etc. I want to use a Tesla model S small rear motor. I don’t have one at the moment but want to design the mounts and check for clashes etc in a 3D model. Does anyone have any drawings or models of the Tesla motor?
Many thanks
Rich
Excellent choice of car - very good looking
If you put your location on the CP it will help
One of my pals in the UK bought a "Transformer" Stratos Replica kit - he never finished it - I wonder if there are any more of those kits left lying in peoples sheds?
It was an excellent kit and the manufacturers started off by making parts for genuine cars
If you are in Bristol, why dont you give Zero-EV a call they should have all the parts in stock and you can come by to view things or discuss the project if you want. (yes I work with/for them)
https://zero-ev.co.uk/
Any idea on what batteries you are looking for? Any specs for the car besides using a small drive unit?
Ioniq EV + ???
Did this project ever happen?
I'd think that the framework chassis of the replica would make it relatively easy to mount motor and batteries in the engine compartment. Easy access from 3 sides and the top seems a rarity in EV builds:
Hood Motor vehicle Automotive exterior Automotive design Vehicle
There's also a rear 'boot' for lighter weight EV parts (charger, etc). The compartment is part of the read clam, so would be good for access without having to open the whole rear clam.
There may be some space for more batteries in the frunk to get a bit of weight over the front wheels, too. This one has had the fuel tank moved to the frunk, for weight distribution when racing:
Automotive tire Vehicle Hood Automotive lighting Car
I guess you'd turn off the regenerative braking, because it's an almost square track:wheelbase car and would swap ends before you noticed.
I think it's the opposite: it's a rear-heavy car, so it can use rear-only regenerative braking. Being on the edge of swapping ends is, of course, the mid-engine performance car experience. ;)
The X1/9 I had waaaay back locked its front brakes on slightly damp roads very quickly.
I remember the X1/9's big brother the Lancia Montecarlo
The demon "mod" for its brakes was to plumb the front direct from the master cylinder and use the servo only on the rear circuit
Even large companies like Fiat are NOT guaranteed to have done the necessary work to get the brake balance correct
Ioniq EV + ???
I always fancied the Monetcarlo. I went through all of the affordable mid-engined cars. Only the Toyota MR2 Mk1 seemed properly engineered.
That Stratos above was built for racing and has a brake bias control in the cabin. I'm not brave enough to fiddle with it! :unsure:
I'll get it out of storage and get it undressed (front and rear clams) and do some measuring to see if an EV conversion is a goer. I need to think through my project goals first though...
1 - 14 of 14 Posts
