1 - 7 of 7 Posts
Discussion Starter #1
ATTN: Vertical Scope.
Bit of a pain in the ass when people post gigantic images inline. Our forums don't auto-resize images.
Ex) https://www.diyelectriccar.com/forums/showthread.php?t=200383
Is this an easy fix?
One fix I've seen before is auto-resizing, but that might only work with forum-hosted images.
Another fix I've seen is where, even if you post a gigantic picture that you have to scroll sideways to see, the text width from the comments never flow past the edges of your window. Both seem achievable with forum software.
If not, it has to be manually fixed by moderators. The usual trick is, if someone flags a post or a mod comes across it, they just edit the post and replace the (IMG) tags with (URL) tags, so people have to click on the images. And then add a little "Edited by mod: Giant pics made links instead".
But we're short on mods. I'll volunteer to fix little stuff like that now and then when I see it, if you give me mod powers.
Thanks.
Hello there,
I have escalated this to the techs.
Please standby for more updates.
Ed
This should be fixed now.
If this is not working, I would suggest turning your extensions and see if that worked.
Ed
1 - 7 of 7 Posts
