Changing a dead lead EV to Lithium and wanted some opinions on my plan. 500 A maximum controller. 144V (12 each 12V 90Ah) existing system. Three LAs were mounted in the front engine compartment and 9 were mounted in seperate battery box in the rear.
Considering using a seperate pack of high power Headway LiFePo4 cells in the front. 48S?P as a standalone pack in front. 48 CALB 100Ah in a second standalone pack. Packs wired in parralel for easy charging.
By my simple Pspice electrical simulation, the lower resistance pack that is closest to the controller should handle a much larger portion of the high current draw. When the current requirement then goes lower, the higher resistance pack in the rear will recharge the lower resistance pack in front. Whole point is to get good performance without damaging the big pack in the rear.
What do you guys think? Good plan? Do I need to current limit the rear pack? (I have a 1000A IGBT module I could use if needed.)
Did I drink to much coffee in coming up with this plan???
Thanks in advance for your inputs.
